JohnD245
Apr 20, 2022Follower
R6080 greyed out settings
firmware version 1.0.0.42
model R6080
operation mode AP
Desire: I want to bridge the R6080 to a cell hotspot
Problem: As I understand the process to accomplish that, the router must be set to Bridge mode
Issue: When I login to the router in admin mode and select Advanced then select Advanced Setup, the option VLAN / Bridge Settings is greyed out and will not respond to being clicked on.
Questions:
Should VLAN / Bridge settings be functional in the R6080?
If so, how may it be enabled?
Thank you
Its because you have it in AP mode.
What does that mean to you?
I ask because "bridge mode" means different things on different contexts.
If you mean as a "wireless bridge" that acts as a repeater between different wireless sources, not all routers can do that, including the R6080 which is pretty well Netgear's most basic recent router.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX.
