TnBigDog
Nov 24, 2022Aspirant
R6080 Router Compatibility
Is the R6080 router (which I assume is wifi 5) compatible with a wifi 6 device? Thanks.
TnBigDog
Thanks! Just to clarify--My new laptop has wifi 6 capability. I realize that I cannot get wifi 6 functionality with the R6080 router, but can I still get wifi 5 functionality when using my wifi 6 laptop? In other words, will the router still work? Thank you!
michaelkenward
Nov 24, 2022Guru - Experienced User
TnBigDog wrote:
... can I still get wifi 5 functionality when using my wifi 6 laptop? In other words, will the router still work? Thank you!
Yes, but you will get hopeless speeds. Nothing will be faster than 100 Mbps. That's the speed limit between your router and the modem.
If your Internet is slower than that, fine.
