ChuckRMI
May 20, 2020Aspirant
R6080 Setup for Defender Video System
I have a Defender video system and a R6080 WiFi Router. The Defender system is plugged into a LAN port on the R6080. the R6080 is connected via LAN to my AT&T Uverse system. The Defender works pro...
- May 20, 2020
Its because you're running a double nat (2 routers in router mode on same network).
https://kb.netgear.com/30186/What-is-Double-NAT
you can try putting the netgear in access point mode.
May 20, 2020Guru - Experienced User
ChuckRMI
Thanks Plemans, that did the tirck and it works great now.
