HJTeix
Oct 19, 2021Guide
R6080/ac1000 router. Bugs !!!
I and many people need a new firmware to fix the 403 forbidden error problem!! The new 1.0.0.52 not solve the problem and disconnecting the cable from modem not works anymore! In 1.0.0.48 it sti...
- Nov 15, 2021
I finally solved the problems!! I bought a new router from another brand!
HJTeix
Oct 19, 2021Guide
Concerning the service, etc., it doesn't matter in the present case. I did all the procedures just to prove that I wouldn't solve the problem that is not just mine but that of many people. As for the 403, I cannot change the settings like DNS and etc on the Internet Setup page. Everyone out there knows that! I'm PC smart and I know all the procedures to test and get modem, router and so on.
Oct 19, 2021Guru - Experienced User
Ok then. Well seems like since you seem to be "PC smart" then you'll need to contact NG support and let them know what your experiencing since we can't seem to help you out.
Good Luck.
- michaelkenwardOct 20, 2021Guru - Experienced User
FURRYe38 wrote:
Well seems like since you seem to be "PC smart" ...
Really?
Solved: Re: 403 forbidden error !! - NETGEAR Communities
Note which section that appeared in.
- HJTeixOct 20, 2021Guide
"Good Solution" !
Thank you for nothing !
- FURRYe38Oct 20, 2021Guru - Experienced User
Good Luck.
- HJTeixOct 21, 2021Guide
What is the best firmware for my router ?? You now ?!!
Everyone has bugs but...
R6080/ac1000.
NETGEAR R6080 Router Firmware 1.0.0.52 bad !!
