Psant
Nov 15, 2016Aspirant
R6100 Magic Jack stop working after 6 mo. I added AC1900 for other devices it worked for 2days 0 now
I have the Netgear R6100 works good I have Magic Jack hard wired into it worked great for 6 months the other day I purchased the Nighthawk AC1900 for other devices all three the R6100 and AC1900 and ...
- Nov 17, 2016
No, I had to change the IP address on the R6100. Also I had the R6100 pluged into the R7000 in the yellow port. I had to change this to plug the R7000 into one of the four out ports on the R6100 along side the magic jack works great now. Thanks, Paul.
Retired_Member
Nov 15, 2016did you connect them to the usb ports for power?
Psant
Nov 17, 2016Aspirant
- Retired_MemberNov 17, 2016
sounds like a doulble nat caused by one router connected to another router which will cause havoc with port forwarding
you might consider using the r7000 in ap mode
