Psant
Nov 15, 2016Aspirant
R6100 Magic Jack stop working after 6 mo. I added AC1900 for other devices it worked for 2days 0 now
I have the Netgear R6100 works good I have Magic Jack hard wired into it worked great for 6 months the other day I purchased the Nighthawk AC1900 for other devices all three the R6100 and AC1900 and ...
- Nov 17, 2016
No, I had to change the IP address on the R6100. Also I had the R6100 pluged into the R7000 in the yellow port. I had to change this to plug the R7000 into one of the four out ports on the R6100 along side the magic jack works great now. Thanks, Paul.
Psant
Nov 17, 2016Aspirant
Retired_Member
Nov 17, 2016sounds like a doulble nat caused by one router connected to another router which will cause havoc with port forwarding
you might consider using the r7000 in ap mode
