yogeesh_r's avatar
yogeesh_r
R6100 Router internet speed issues
Internet speed is reduced after R6100 router connectivity. If I connect directly (withour router) and test the speed, I am getting full speed (250/100). But when I test after connecting R6100 router (even with wired) the speed is reduced to (100/100). Please let me the reason and any fixes.
  • The issue is  a LAN / WAN port speed limitation on the R6100.
    LAN 10BASE-T or 100BASE-Tx, RJ-45 WAN 10BASE-T or 100BASE-Tx, RJ-45   - Manual - Page 119
    YOu have two options, purchase a new router that support 1000Mbps LAN  / WAN, or downgrade your Internet service
    • yogeesh_r's avatar
      yogeesh_r
      Thanks for your replay. Please let me know which Router support 1000Mbps LAN speed.
      • netwrks's avatar
        netwrks
        Master
        Anything from NG R6300 and up.
