JackVR's avatar
JackVR
Tutor
Feb 05, 2023
R6100 router
My r6100 router is dropping my internet connection a few times per week. My internet provider indicates that my router is the issue. The recommendation is to clear the cache on the router. I’m not overly savvy when it comes to these issues. Will this potentially fix the issue? If so, how do I do this without causing other problems. Note that the router is 8 years old or so. Any input would be appreciated.
  • JackVR's avatar
    JackVR
    Feb 09, 2023
    Thanks for the reply. Guess it’s time to upgrade.
  • plemans's avatar
    What actually happens? Thats key.
    Saying it doesn't work doesn't tell us much.
    What happens with wireless devices (don't say "they don't work)?
    And wired devices?
    What modem/gateway is it connected to?
    What firmware is on the router?
    What fixes the issues.
    Details are key. We need good descriptions of the problem and what your setup is to help
    • JackVR's avatar
      JackVR
      Tutor
      Thanks for your reply. My R6100 router is connected to a modem supplied by Spectrum. My internet connection is lost at random times once or twice a week. All my wireless devices, iPhone, iPads, smart tv, Blink camera etc indicate “unable to connect to the internet” when the connection is lost. The fix is to reboot both the modem and the router at the same time. Per the genie app, I am up to date with firmware version v1.0.1.22. Per Spectrum, there are no issues on their end. My router is 8+ years old. My question is if clearing my router’s cache(?) will potentially fix the issue?
      Thank you for your time.
      Jack
      • microchip8's avatar
        microchip8
        Master
        There is no router cache. Best thing you can do is doing a factory reset and reconfigure from scratch - push the reset button at back for 10 seconds then release. This is especially recommended if you've done multiple firmware upgrades in the past but kept your settings.
        Also do note that the R6100 only has 100 Mbps LAN ports. If you upgrade your connnection to more than 100 Mbps, you'll hit a bottleneck. I recommend upgrading your router to a more recent one, like the RAX models.
