Longmire
Sep 29, 2017Aspirant
R6100 w/ no active LAN ports, after reset, can I access router wirelessly
I have full use of the WIFI aspect of my R6100 router. None of the LAN ports work w/ any of my devices (TV, desktop, laptop). I use both frequencies, 2.5 and 5, and both work w/ my devices. I've done...
- Sep 29, 2017
> If I do that, and the LAN ports still don't work, (making hard wire
> router setup impossible) will I be able to access the router wirelessly
> to re-set my security settings?
Before you do the reset, you might want to read the User Manual.
Especially the part where it explains how to configure the router. I
quote (page 14):
2. Make sure that your computer or wireless device is connected to
the router with an Ethernet cable (wired) or wirelessly with
the preset security settings listed on the bottom label.
Visit http://netgear.com/support (while you still can), put in your
model number, and look for Documentation.
antinode
Sep 29, 2017Guru
quote (page 14):
Longmire
Oct 02, 2017Aspirant
Reset was easy peasy. I got my LAN ports re-activated as a result. Thanks for encouragement. I don't do much networking so it is a little foreign to me.
