Corwin9s's avatar
Corwin9s
R6100 wifi Issues
hello. I'm on Windows 7 computer and I use the R6100 firmware 1.0.1.14.   Problem: wifi stops working suddenly and internet is of course no more reachable. Solution: reboot the R6100   this is w...
  • DexterJB's avatar
    Sep 20, 2017
    Hi Corwin9s,
    1. Have you tried doing a factory reset on the router?
    2. Does the issue persist on both bands (2.4GHz and 5GHz)?
    3. Have you tried changing the wireless channel for either bands?
    4. Are your wired devices affected?
    Dexter
    Community Team
