sirianlady's avatar
sirianlady
r6100 wifi quit working
I have an R6100 router.  It has always worked well, but now the wifi does not work.   It is plugged into a cable modem.  My computer shows that the wifi is going, but I cannot get on the internet...
  • shadowsports's avatar
    shadowsports
    Sep 24, 2018
    Greetings,
    Next step it to perform internet seup from the Basic Tab in the routers user interface.  Let us know if this resolves.
    Also, have you or the ISP changed out the modem recently?
