George1979
Sep 22, 2016Aspirant
R6100 Wireless Issues
Just bought a new R6100 router. With my Mac hooked up to the router the internet works just fine. However, the wireless is not working at all. I'm getting a DHCP error. Any thoughts?
- Sep 22, 2016
Problem solved. The problem had to do with the router being I initialized in AP or access point mode. Unfortunately this was the NETGEAR recommended setting. Once this feature was disabled things worked normally.
Retired_Member
Sep 22, 2016Did you setup wireless?
What settings did you use?
Is your wifi card set to DHCP?
- George1979Sep 22, 2016Aspirant
Yes. I have set up wireless. My computer connects to my neighbors network with no issues. My kindle connects to my network without problem. My MacBook will not connect to my wireless network. Works with the cable connected.
IPv4 is set to "using DHCP" and IPv6 is set to automatically.
Wi-Fi security is set to WPA2-PSK. Password is correct.
Despite my Mac not connecting wirelessly, the NETGEAR Genie says I'm connected.
- Retired_MemberSep 22, 2016
the genie app is rubbish in my opinon delete for now until we get it working
this is a replacement router ? If so are you using same SSID and PW? If yes go into imac wifi and delete any saved connections to home ssid
Did you have another DHCP server running when installing router ....if router detects another dhcp server it switches to AP mode.
