George1979's avatar
George1979
R6100 Wireless Issues
Just bought a new R6100 router. With my Mac hooked up to the router the internet works just fine. However, the wireless is not working at all. I'm getting a DHCP error.    Any thoughts?
  • George1979's avatar
    George1979
    Sep 22, 2016
    Problem solved. The problem had to do with the router being I initialized in AP or access point mode. Unfortunately this was the NETGEAR recommended setting. Once this feature was disabled things worked normally.
