probneedhelp
Mar 16, 2022Aspirant
R6120 | AC1200 Issue: Can connect to 2.4 ghz and 5ghz channel but receive no internet
About a week ago my internet on both 2.4ghz and 5 ghz channels started to get spotty and then eventually stopped working. I could connect to the channels but could not access the internet. The strang...
probneedhelp
edit* - Attempt rollback to V1.0.0.80 via the netgear router admin portal and still no luck
FURRYe38 would you happen to have an idea?
michaelkenward
Mar 17, 2022Guru - Experienced User
What does that mean?
This?
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- probneedhelpMar 23, 2022Aspirant
Thanks for responding.
The modem is a netgear CM500.
Correct! I manually rolled back my firmware to an older version V1.0.0.80. This did not fix the issue either.
- michaelkenwardMar 24, 2022Guru - Experienced User
It may help to reboot the whole network in the right order.
Be sure to restart your network in this sequence:- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
