hopc
Feb 11, 2018Follower
R6120 Ac1200 router
can I bridge 2 R6120 routers
- Feb 18, 2018
Hi hopc,
If what you want to do is use the other R6120 as an Access Point, you can check page 113 on the user manual linked below.
http://www.downloads.netgear.com/files/GDC/R6120/R6120_UM_EN.pdf
Dexter
Community Team
antinode
Feb 11, 2018Guru
What does "bridge" mean to you here? What is the actual problem
which you are trying to solve?
