rtbc's avatar
rtbc
r6120 as wireless bridge
I have an R6120 I want to use as a wireless bridge, ie it connects passively to exisitng wifi and distributes network via ethernet. However I don't think it can do it, can anyone confirm? Thanks
  • michaelkenward's avatar
    Nov 10, 2018
    There is a manual for the R6120 somewhere at the end of this link:
    >>>> R6120 | Product | Support | NETGEAR <<<<
    I see no suggestion that this device can operate as a Wireless Distribution System (WDS) or repeater.
    It will work as an access point. See the bit in the manual Use the Router as a WiFi Access Point Only.
