rtbc
Nov 09, 2018Aspirant
r6120 as wireless bridge
I have an R6120 I want to use as a wireless bridge, ie it connects passively to exisitng wifi and distributes network via ethernet. However I don't think it can do it, can anyone confirm? Thanks
- Nov 10, 2018
There is a manual for the R6120 somewhere at the end of this link:
>>>> R6120 | Product | Support | NETGEAR <<<<
I see no suggestion that this device can operate as a Wireless Distribution System (WDS) or repeater.
It will work as an access point. See the bit in the manual Use the Router as a WiFi Access Point Only.
michaelkenward
Nov 10, 2018Guru - Experienced User
rtbc
Nov 14, 2018Aspirant
Thanks for the reply, indeed I was hoping I'd missed something but unfortunately looks like not. Need to replan my design then!
cheers
