IDpotato2019
Mar 17, 2019Aspirant
R6120 Can this model be bridged
If so can you point me to some instructions?
Thanks.
- Mar 18, 2019
If you mean can you use it as a wireless repeater in a Wireless Distribution System (WDS) system, then, according to the manual, the answer appears to be no.
You can use the R6120 as a WiFi Access Point, wired back to a router.
michaelkenward
Mar 18, 2019Guru - Experienced User
- IDpotato2019Mar 18, 2019Aspirant
Thank you all for your help.
