Aleksander's avatar
Aleksander
R6120 drops connections on both wifi bands
Hello   I recently got a new Wi-Fi router and it seems it keeps dropping Wi-Fi connections. Unable to reach even the ruter itself via WiFi. Disconnecting and connecting power helps but only for f...
  • Aleksander's avatar
    Aleksander
    Jan 04, 2019
    Thank You so much for Your quick and elaborate response. I realy appreciate that. The cpmpetency of Netgear in supporting their products is outstanding and thanks to You I was able to resolve the issue in no time. I will gladly recomment Netgear to my friends whenever asked for advice on network gear. It was a real pleasure visiting this forum. Once again Thank You s much. You are a definition of how customer support and community support should look like.
