BuckleBomb's avatar
BuckleBomb
R6120 External Access via public IP address
Im trying to set up access some network devices externally on the Netgear R6120.  Ive done this kind of set up a couple times before with no issues and different routers.  So ive set up the port forw...
  • antinode's avatar
    Dec 10, 2019
    > [...] when i google my public IP address it is different to what the
    > router internet port ip address says [...]
       That's likely your problem, but without the actual (not "FAKE")
    address for the WAN/Internet IP address of the router, it's tough to be
    sure.  Is it a private address?  Plug it into the form at
    "https://whois.arin.net/".
    > [...] must be missing the key words of my problem.
       Try "Carrier-grade NAT"?
          https://en.wikipedia.org/wiki/CGN
          https://en.wikipedia.org/wiki/Carrier-grade_NAT
    > So i attempted to access using both addresses [...]
       From where, the outside world?  You need to talk to the router
    (WAN/Internet interface), but, if it has a non-routed address, then you
    can't reach it (from the outside world) at that address.  And the ISP's
    CGN router knows nothing about your desire for port forwarding.
    > Any suggestions?
       Ask your ISP if you can get a public address?
