bhibner
Oct 15, 2021Tutor
R6120 Firmware Problem
How do I update my firmware without wireless internet? My firmware was updating when my router lost power. Now I can't access the interent to complete the firmware installation and the power light is...
Oct 15, 2021Guru - Experienced User
did you extract it?
You don't actually "open" it to upload it.
You extract it once downloaded and then log into the router and follow the manual install process.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
bhibner
Oct 15, 2021Tutor
When I click extract, it takes the files to a folder and the only available files are the release notes and a disc image file. Am I doing something wrong?
- plemansOct 15, 2021Guru - Experienced User
nope. the disc image file is the one that gets uploaded. follow the manual update process that I linked to now.
- michaelkenwardOct 16, 2021Guru - Experienced User
It isn't actually a " disc image file". Just something with the same extension.
Just to make life entertaining, for some devices Netgear provides firmware as .chk files
