LC_LIM
Nov 10, 2017Aspirant
R6120 FTP HTTP (via Internet) not working
Router : R6120 connect 500G harddisk to USB port Try FTP and Http within home wifi working OK. Use IE, Explorer on PC working.Use ES explorer on phone also working. But, when try FTP and HTTPS (via in...
- Nov 11, 2017
> the router is connected to a fiber optics modem.
Not a very detailed description of anything.
> so it is the modem that give 100.100.xxx.xxx to the router ?
Yes.
> as the Internet service need to dial up, i think i cannot use it as AP.
What does "dial up" mean here? What is "it"?
> i think i will have to use filezilla server and port forwarding , am I
> correct ?
If you use the R6120 as a wireless access point, then I don't know if
its ReadySHARE features (FTP/HTTP access to USB storage) will work.
In any case, if the fiber modem+router is the router with the public
IP address, then that router is the one which must do the port
forwarding. If you leave the R6120 as a full-function router (behind
the fiber modem+router), then you would want the fiber modem+router to
forward the FTP and HTTP[S] ports to the R6120. Devices which are
connected to the R6120 would still have "double NAT", but you may not
care.
I know nothing about your fiber modem+router, so I can't say if it
can do port forwarding. If it has a bridge mode, then that might solve
all your problems, because that would make the R6120 the router with the
public IP address.
LC_LIM
Yes, boxes checked ! Thanks.
LC_LIM
Boxes checked still not working.
The given IP address to access FTP is always 100.100.xxx.xxx . When I checked my external IP address, it is 117.83.xxx.xxx. Is this a problem ?
Also I try to set the IP address to 117.83.xxx.xxx, no internet access at all .
Please help
Thank you.
- antinodeNov 10, 2017Guru
> problem ?
Probably. What feeds the R6120? Apparently, it's some kind of
(modem+)router, and cascading two routers leads to problems like this,
often described as "double NAT".
The usual solutions to these problems involve disabling the router
features on one of the two devices. One way would be to put the
(unspecified) (modem+)router into modem-only or "bridge" mode. Another
would be to reconfigure the R6120 as a wireless access point.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. In the User Manual, look for "Use the Router as a
WiFi Access Point Only" (page 113). Or, in the web interface:
ADVANCED > Advanced Setup > Wireless AP
Which method to use depends on which router has the better feature
set.- LC_LIMNov 11, 2017AspirantThanks for helping. Yes , the router is connected to a fiber optics modem. so it is the modem that give 100.100.xxx.xxx to the router ? as the Internet service need to dial up, i think i cannot use it as AP. i think i will have to use filezilla server and port forwarding , am I correct ?
- antinodeNov 11, 2017Guru
Yes.
> correct ?
care.
public IP address.
