Ruthannocala
Apr 06, 2021Aspirant
R6120 issues
Have to replace 3 yr. old Net Gear, I'll DEFINITELY not be replacing with this brand!
Apr 06, 2021Guru - Experienced User
Just here to vent or do you want help trying to fix the router?
This is the community support forum where members of the public try to help out.
We're not netgear.
So just trying to figure out what your goal is.
Thanks
useruser38676
Apr 06, 2021Tutor
I am confused by your reply "we are not netgear".
The URL of this forum says netgear.com
Are we then on "unpaidVolunteersHelp.org?
- plemansApr 06, 2021Guru - Experienced UserIf you want to be an a--hole about it sure. Or you could think of it similar to how a stranger pulls over when you're stranded on the road to help. They're not mechanics or paid. They're just people wanting to help others.
- antinodeApr 06, 2021Guru
Apparently, you're _very_ easily confused.
Does that mean that _you_ are Netgear, too? Because anyone who
participates in discussions here must be? Duh?I see that there's a "morons.org", too, which might be a more
appropriate place for your duplicative, time-wasting rants.
