HollyAnnQB's avatar
HollyAnnQB
R6120 not broadcasting and not able to access www.routerlogin.com/net or the IP!!!?? PLEASE HELP?
I have recently moved and was able to get the wifi broadcasting and was cable connected just fine UNTIL I reset it to try and get into the website to make changes. Now the Router is not even broadcas...
  • michaelkenward's avatar
    May 29, 2020
    Moving house means that you now have a completely different internet setup.
    The first thing to do is to reset the router and everything else that moved with you.
    You may also have a different modem. In that case it may need tweaking to get it to play nicely with your router.
    Go back to square one and set up the network from scratch.
