HollyAnnQB
May 28, 2020Aspirant
R6120 not broadcasting and not able to access www.routerlogin.com/net or the IP!!!?? PLEASE HELP?
I have recently moved and was able to get the wifi broadcasting and was cable connected just fine UNTIL I reset it to try and get into the website to make changes. Now the Router is not even broadcas...
- May 29, 2020
Moving house means that you now have a completely different internet setup.
The first thing to do is to reset the router and everything else that moved with you.
You may also have a different modem. In that case it may need tweaking to get it to play nicely with your router.
Go back to square one and set up the network from scratch.
michaelkenward
May 29, 2020Guru - Experienced User
HollyAnnQB
May 31, 2020Aspirant
michaelkenward wrote:
HollyAnnQB wrote:I have recently moved and was able to get the wifi broadcasting and was cable connected just fine UNTIL I reset it to try and get into the website to make changes.
Thank you for your help, i really appreciate you being nice and lending a second pair of eyes - so to speak! I will be tweeking the new modem and then reseting my nighthawk. i hope this works, although i do belive you are correct.
