Mahadi132
Jun 09, 2022Aspirant
R6120 Power LED is blinking
Recently I buy this R61200 router ,but the Power LED is blinking all time. i try to upload firmware TFTP client on Microsoft Windows but the problem is when i turn my router off for 10 seconds but Po...
michaelkenward
Jun 10, 2022Guru - Experienced User
If this is a new router an it behaved like that our of the box, then it is a dud and should go back to whoever sold it to you.
i try to upload firmware TFTP client on Microsoft Windows but the problem is when i turn my router off for 10 seconds but Power LED to light not orange and not start flashing.
TFTP is not the simplest of tasks. It might help to follow one f the various videos out there.
Timing is the essence.
Mahadi132
Jun 10, 2022Aspirant
I'm download TFTP not work ,, than try to download tftp2.exe but 403 error
- michaelkenwardJun 10, 2022Guru - Experienced User
I don't understand that.
You should not need to download anything. Enable TFTP in Windows and use that.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
And do check that video.
