SamUsesNG
Aug 09, 2021Follower
R6120 powerlight is flashing after bad update
Title says it all, basically I tried to update my router, and accidentally unplugged it while doing that. Now the green power LED is slowly flashing and the router is doing nothing.
michaelkenward
Aug 10, 2021Guru - Experienced User
Sadly, unplugging the thing may have done serious damage to the router's firmware. The manual for your device will confirm that the flashing power light you see is a sign of corrupt firmware.
First see if this gets you anywhere:
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
The chances are low, but you never know, and you won't do any more damage.
If that fails, then try this:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
It is a more severe "recovery reset". If that works, and the power light stops flashing, then you may be able to so this:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
If that fails, then this is the next thing to try:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This also explains how to enable TFTP on a Windows PC.
TFTP isn't the easiest operation – it can take several attenmpst to get the timing right – so if you are forced to use it try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same.
The good news is that TFTP has rescued many a dead device.
If that doesn't work, come back for other suggestions.
