thejohnsolo
Mar 20, 2023Tutor
R6120 Repeatedly gives error message when attempting to set up the guest network
Just updated the firmware which caused the router to factory reset itself. When I got everything back up and running, I tried to turn on the guest network. Every time I do, it gives me an error messag...
Mar 20, 2023Guru - Experienced User
What error message are you getting?
What happens if you use the default SSID name and a PW of Password123?
thejohnsolo
Mar 23, 2023Tutor
It doesn't give an error code. It just says "Configuration Error" and on the bottom it says, "The Router could not apply your new settings. Check your WiFi connection and try again." I have tried the default SSID, but not that password. Any ideas?
