topgun1953
Sep 08, 2024Tutor
R6120 seems to block Ecobee thermostat
After several months of use, my Ecobee3 Lite can no longer connect to their server. I first noticed this after a brief power failure. I've had failures several times though with issue. If I us...
- Sep 11, 2024
https://dnschecker.org/ip-blacklist-checker.php
I am using access control.
Yes, I've reset everything a zillion times. hahaha The ecobee is not blocked by the router. It CAN ping various addresses okay but it won't connect to whatever servers ecobee uses UNLESS I bypass the router via a hotspot. My ISP, spectrum, tells me my IP address scheduled to be changed next Thursday so I'll see what happens then. thanks for your input
topgun1953
Sep 08, 2024Tutor
***edit: I've had power failures before withOUT failures.
