topgun1953
Sep 08, 2024Tutor
R6120 seems to block Ecobee thermostat
After several months of use, my Ecobee3 Lite can no longer connect to their server. I first noticed this after a brief power failure. I've had failures several times though with issue. If I us...
- Sep 11, 2024
https://dnschecker.org/ip-blacklist-checker.php
I am using access control.
Yes, I've reset everything a zillion times. hahaha The ecobee is not blocked by the router. It CAN ping various addresses okay but it won't connect to whatever servers ecobee uses UNLESS I bypass the router via a hotspot. My ISP, spectrum, tells me my IP address scheduled to be changed next Thursday so I'll see what happens then. thanks for your input
Sep 11, 2024Guru - Experienced User
topgun1953 wrote:
Thank you for the reply. Changing the DNS servers didn't help. My latest thinking is that my IP address is being blocked by Ecobee. I noticed my laptop when wired directly to modem and used as a hotspot for ecobee, it connects fine. The only difference, I see, is that the IP address is different for the laptop vs the router. I found my IP for the router, is blacklisted on 3 sites. Presumably for Spectrum allowing some sort of spamming going on from their email address (I don't use it). So I'll go down this road and see what I can do.
How did you find this?
Are you using access controls?
Try a reset on the router or ecobee?
topgun1953
Sep 11, 2024Tutor
