topgun1953
Sep 08, 2024Tutor
R6120 seems to block Ecobee thermostat
After several months of use, my Ecobee3 Lite can no longer connect to their server. I first noticed this after a brief power failure. I've had failures several times though with issue. If I us...
- Sep 11, 2024
https://dnschecker.org/ip-blacklist-checker.php
I am using access control.
Yes, I've reset everything a zillion times. hahaha The ecobee is not blocked by the router. It CAN ping various addresses okay but it won't connect to whatever servers ecobee uses UNLESS I bypass the router via a hotspot. My ISP, spectrum, tells me my IP address scheduled to be changed next Thursday so I'll see what happens then. thanks for your input
synfm
Feb 24, 2025Aspirant
I plan to contact their support again tomorrow. I think they are blocking my IP. When I tried to telnet 161.38.184.16 8089 from my desktop (connected to ethernet), It said "Connected to 161.38.184.16" and then immediately "Connection closed by foreign host". Then I connected to my VPN, switching to any random IP address, and did the same, it now stayed connected for 10 seconds before it was closed. I think if my router or my ISP is blocking them, I shouldn't see the connected message from telnet without VPN.
michaelkenward
Feb 26, 2025Guru - Experienced User
Telnet?
Odd way of trying to get in. They aren't likely to welcome that.
Disclaimer: Just another user with time on their hands.
- synfmFeb 26, 2025Aspirant
That's to prove that it's not my router or ISP blocking the traffic. There's a difference between telnet immediately close after connection vs connection timeout.
I already provided this info to ecobee and waiting for responses.
