lbermudez
Mar 25, 2021Aspirant
R6120 use local dns server
How can I use my own dns server for the other computers on my network without manual setting all my devices? Advanced tab setup Internet setup then found the line Domain Name server (DNS) Addr...
lbermudez
Mar 26, 2021Aspirant
As i have stated abobe I went under internet setup if I change to my own dns server at 192.168.2.9 I have no internet for the host 192.168.2.9 As in their is no connention. Command line apt update says could not resolve and the web browser says DNS_PROBE_FINISHED_BAD_CONFIG
I have tested out my own dns sever by using it for years by changeing the ipv4 setting on my wifi card dns servers and search domains to 192.168.2.9. Other computers on the network can still get the internet using my dns server but not the host 192.168.2.9.
under Lan Setup i have the ip address 192.168.2.9 next to the device name and MAC address saved.
/etc/resolv.conf
nameserver 127.0.0.53
options edns0 trust-ad
search 192.168.2.9 127.0.0.1
pihole is on port 53 dns server
stubby is on port 8053
antinode
Mar 26, 2021Guru
> As i have stated abobe I went under internet setup [...]
It was unclear above, and it's unclear here.
> [...] I have no internet [...]
See above. Not an improvement over:
> Can not get internet. [...]
Same questions (still) apply.
> I have tested out my own dns sever by using it for years [...]
And how, exactly, did you test it _now_?
> [...] Other computers on the network can still get the internet using
Huh? I thought that "the host 192.168.2.9" _was_ your "my dns
server". Or do you mean that your DNS server _itself_ ("192.168.2.9")
can't resolve addresses, or what? At least one of us is confused.
I don't know what that means; it's not a useful problem description.
It does not say what you did. It does not say what happened when you
did it. As usual, showing actual actions (commands) with their actual
results (error messages, LED indicators, ...) can be more helpful than
vague descriptions or interpretations.
You're talking about Address Reservation? As in:
ADVANCED > Setup > LAN Setup : Address Reservation? (Did you notice
that the most significant part of that, "Address Reservation", appears
noplace in your description?)
> /etc/resolv.conf
On _what_? Your name server?
"127.0.0.53"? Huh? What's at _that_ addresss?
Huh? The "search" option should specify default domain name(s),
usually one, not multiple IP addresses.
https://man7.org/linux/man-pages/man5/resolv.conf.5.html
I can't tell if you don't know what you're doing, or if you can't
type what you're really doing, or both, or what, but what you've written
makes no sense to me.
I can't (yet) see your pictures. In-line images must be approved
by a moderator before others can see them. The time required varies.
Attachments have no such limitation. Of course, attachments have their
own one-per-message limitation.
You might try a "/etc/resolv.conf" which makes more sense, like, say:
nameserver 127.0.0.1 [or: 192.168.2.9]
options edns0 trust-ad [If you want.]
If you decide to use a local domain name, then you might add a
"search <my_local_domain_name>" option.
