KingEe's avatar
KingEe
Follower
Apr 12, 2021
R6120
I need a new password. but I haven’t use this Router for while so I can’t connect to the WiFi. My services from my provider is there. But I can’t login into routerlogin.net cuz I have no wifi
1 Reply
  • plemans's avatar
    You can hardwire a pc/laptop into the router. This bypasses needing the wifi password. then you can log into it and view/change the ssid. You'd still need to know the log in for the router (which you'd need to change it over wireless as well)
