GurjitSingh
Sep 22, 2022Follower
R6120
I reset my wifi router and connected it with the app. After 5 min it stopped and power light and USB started blinking alternatively. Help me fix it
Sep 22, 2022Guru - Experienced User
Are you able to factory reset it again?
Are you able to access it if you hardwire a device into it?
