bwareham
Oct 11, 2021Aspirant
R6200 and no-ip
I am trying to set up a dynamic DNS service on my router, but the only option on the dropdown menu is DynDNS.org, which no longer has a free tier. Since I don't want to spend $55/year I'd like to use...
- Oct 13, 2021
Just to close the loop here, I ended up using a dynamic DNS service -- dynu.com -- that doesn't require setup with the router. It uses client software on the computer to check every two minutes for a change to the DNS address assigned by the ISP. I have had it running for a couple days now, through at least one address change, and it seems to work fine.
bwareham
Oct 13, 2021Aspirant
