APlone
Jul 10, 2021Follower
R6200 Restore to Factory Defaul by Itself
In the last 2 month i had 2 of this routers that after power down and power back up, router did restore back to default setting in it is own. They are located at 2 different locations, different inte...
Jul 11, 2021Guru - Experienced User
If you're on the current 1.0.1.58 firmware, you could always try downgrading and disabling auto-update.
I've occasionally seen versions of firmware that cause random factory resets. If you've got 2x devices, put the newer firmware on one and an older version on the other. If only one resets after that, you'll know the cause.
