ward74
Jul 29, 2016Aspirant
R6200v2 changing channels on 5GHZ
How do I change the chanel for the 5 GHZ band, when it came with "auto" set as the default?
- Jul 29, 2016
Never use auto selection. clikc on it change it to higher channels like 149, 153. And band width 4o Mhz.
VE6CGX
Jul 29, 2016Master
- ward74Aug 15, 2016Aspirant
I change the channels and it changed the 5G signal for my FireStick from -72 to -61, I did not find any channel where I could get -40 dBm.
These are the results when I ran WIFI Analytcs.
Can you tell me why the Netgear 30-5G signal is -46, but the Firestick is -61, the Firestick is 8 ft. from the router?
SSID SIGNAL(dBm CHANNEL SECURITY BSSID
NETGEAR 30 -30 5 WPA2SK 6c:b0:ce:ab:73:bbNETGEAR 30-5G -46 157 " 6c:b0:ce:ab:73:ba"
DIRECT-e1-FireTV_c463 -61 157 " 76:c2:46:8c:b0:12
