ward74
Jul 29, 2016Aspirant
R6200v2 changing channels on 5GHZ
How do I change the chanel for the 5 GHZ band, when it came with "auto" set as the default?
- Jul 29, 2016
Never use auto selection. clikc on it change it to higher channels like 149, 153. And band width 4o Mhz.
VE6CGX
Jul 29, 2016Master
ward74
Aug 15, 2016Aspirant
I change the channels and it changed the 5G signal for my FireStick from -72 to -61, I did not find any channel where I could get -40 dBm.
These are the results when I ran WIFI Analytcs.
Can you tell me why the Netgear 30-5G signal is -46, but the Firestick is -61, the Firestick is 8 ft. from the router?
SSID SIGNAL(dBm CHANNEL SECURITY BSSID
NETGEAR 30 -30 5 WPA2SK 6c:b0:ce:ab:73:bb
NETGEAR 30-5G -46 157 " 6c:b0:ce:ab:73:ba"
DIRECT-e1-FireTV_c463 -61 157 " 76:c2:46:8c:b0:12
