KentB
Nov 03, 2015Tutor
R6200V2 Doesn't Seem to Bridge
I just had Frontier service installed which requires the use of their FIOS wireless router. I have that downstairs and all my wireless devices/tv/ect connect just fine. I want to set my Netgear route...
- Nov 03, 2015
Let's go through the steps.
- You logged into the R6200 and went to ADVANCED > Advanced Setup > Wireless Settings and clicked on Enable Bridge mode?
- You clicked on the button setup bridge mode wireless settings?
- You proceeded to enter the Wi-Fi frequency, name, password, and security mode used by your FIOS router and clicked Apply?
- You clicked Apply again on the Advanced Wireless settings page?
At this point, log into your FIOS router and confirm that it can see the R6200. The R6200 should have obtained an IP address. You should be able to log into the R6200 using this IP address.
If necessary, reboot your desktop and printer upstairs to force them to DHCP for IP addresses.
TheEther
Nov 03, 2015Guru
KentB
Nov 04, 2015Tutor
Thank you soo much! I had trouble with these steps last night but then reset everything and tried again. This time, I started by changing the IP on the netgear router temporarily to 192.168.0.1 (it was later set to 192.168.1.6 by the FIOS router). I don't know if that helped but what happened last night was that I could no longer log into my FIOS router from AP - as both routers had the same IP -192.168.1.1 - attempts to log into my FIOS router was bringing up the Netgear interface from both sides of the bridge (which was telling me the wireless was working between them but something was still messed up).
All seems to be working now. Thanks again TheEther!!!
