zaPURE
Jan 22, 2017Aspirant
R6220 - 5G max connection speed up 173mbps no 867 option availabe
Hi I can't seem to get my router to show the options that allow the 5g interface to offer 867 Mbps connection it currently only allows up to 173mbps When I go to wireless setting under the W...
- Jan 22, 2017
What region is your router set to? Someone else had a similar issue and their region was set to something like Israel. Perhaps there are region-specific limitations imposed by regulation.
TheEther
Jan 22, 2017Guru
zaPURE
Thank you, that was it changed the region from Africa to United states and all the options appeared
