Barrytown
Feb 18, 2021Follower
R6220 - Can't set VPI/VCI
I would like to use my r6220 router and return my isp provided router. I have the PoE login and password from my provider as well as the ADSL settings. The ADSL setting is not in the genie set up, I ...
antinode
Feb 18, 2021Guru
What, exactly, are you trying to replace?
> [...] The ADSL setting is not in the genie set up, [...]
Because you're trying to replace some (unspecified) DSL modem+router
with a (modem-less) router? I think that I can explain that.
Where did you intend to stick your phone/DSL wire? (Hint: sticking
it into an Ethernet hole, where it doesn't really fit, would be a bad
idea, for multiple reasons.)
