Kempes7475
Jun 04, 2022Tutor
R6220 - DLNA scanning on USB HDD kills router - only reset helps
Hi. Situation looks like this. Netgear R6220 newest firmware, HDD USB Toshiba 500GB connected via routers USB. DLNA server started on router. HDD and DLNA server are visible in local network. When I ...
Jun 05, 2022Guru - Experienced User
Advice? Don't use the dlna server on the router?
Only reason I said this is dlna server support was pulled on the newer fancier devices that have more power. And the R6220 is a base model router with minimal cpu/ram/flash. And it could be your music setup (file structure, formating, etc) is putting to much of a burden on the cpu to manage whats going on.
Kempes7475
Jun 05, 2022Tutor
Understood. It's clear. Whata a pity that it's not working. I counted on this function. I expected that router will be able to hold DLNA server (for TV, mobile phones) without turning on computer. But it can not handle even music files not mention about video files. Thanks for reply!
- plemansJun 05, 2022Guru - Experienced User
Music doesn't take much cpu but it could be how you have it setup.
What format is your usb drive in?
Do you have all your music in a single folder or is it through several sub-folders (folder within a folder within a folder)?
What format is the music in?- Kempes7475Jun 05, 2022Tutor
HDD is NTFS. Folders structure looks like this: HDD Root ---> !!!DLNA ---> !!!MUSIC ---> (Artist Name) ---> (Album Name) ---> files. Music format 80% of M-P-3 files 20% of F-L-A-C files. In (Album Name) folders are JPG's with covers and sometimes LRC files with lyrics.
Got a jump drive sitting around?
Try tossing 10-15 of the mp3 files in a folder and connecting it to the router and see if it works.
Or try the flac files.
That could help to see if its how the folder structure is setup.
Just try 1 or the other (mp3 vs flac) to see if its a formating of the music.
