FoxzSnake
Nov 12, 2015Tutor
R6220 - Does NOT support IPv6
Before purchased R6220, I have checked support web site (http://kb.netgear.com/app/answers/detail/a_id/19308/~/ipv6-compatibility-on-netgear-routers) shows that it does support IPv6 on the latest fir...
- Aug 01, 2017
Hi all,
Please update the router to the latest firmware version (1.1.0.50).
Dexter
Community Team
TheEther
Nov 12, 2015Guru
IPv6 settings should be under ADVANCED > Advanced Setup > IPv6.
- FoxzSnakeNov 12, 2015Tutor
Yes, usually it should be there, and I have tried firmware 1.0.0.17 and 1.1.0.31, but both doesn't have.
- DexterJBNov 13, 2015NETGEAR Moderator
Hi FoxzSnake,
The IPv6 feature for the R6220 will be added to a future firmware release but no ETA has been provided yet.
Dexter
Community Team
- Seta-SanNov 28, 2015Star
i sort of expect that firmware update soon. my isp is turning ipv6 on next month. i bought the R6220 to upgrade an old wrt54g and to get ipv6.
on your site it's stated as supporting ipv6 and it's unacceptable that it doesn't.
