FoxzSnake
Nov 12, 2015Tutor
R6220 - Does NOT support IPv6
Before purchased R6220, I have checked support web site (http://kb.netgear.com/app/answers/detail/a_id/19308/~/ipv6-compatibility-on-netgear-routers) shows that it does support IPv6 on the latest fir...
- Aug 01, 2017
Hi all,
Please update the router to the latest firmware version (1.1.0.50).
Dexter
Community Team
Seta-San
Dec 16, 2015Star
i feel like an ETA is owed seeing that this was an advertised feature on this device on your very website.
- DarrenMDec 17, 2015Sr. NETGEAR Moderator
Hello Seta-San
The IPV6 options should be located in the Advanced then Advanced Setup then IPV6 if you are unable to see this try to use a different browser and if you still cant see the settings can you post a screenshot so I can send this to our SMEs to investigate why those settings are not showing up. Hope to hear your feeback.
DarrenM
- FoxzSnakeDec 23, 2015Tutor
Here is the screenshot, and it does not have IPv6 option.
I hope it wiil come back soon. :smileysad:
