FoxzSnake
Nov 12, 2015Tutor
R6220 - Does NOT support IPv6
Before purchased R6220, I have checked support web site (http://kb.netgear.com/app/answers/detail/a_id/19308/~/ipv6-compatibility-on-netgear-routers) shows that it does support IPv6 on the latest fir...
- Aug 01, 2017
Hi all,
Please update the router to the latest firmware version (1.1.0.50).
Dexter
Community Team
DarrenM
Dec 17, 2015Sr. NETGEAR Moderator
Hello Seta-San
The IPV6 options should be located in the Advanced then Advanced Setup then IPV6 if you are unable to see this try to use a different browser and if you still cant see the settings can you post a screenshot so I can send this to our SMEs to investigate why those settings are not showing up. Hope to hear your feeback.
DarrenM
FoxzSnake
Dec 23, 2015Tutor
Here is the screenshot, and it does not have IPv6 option.
I hope it wiil come back soon. :smileysad:
