FoxzSnake
Nov 12, 2015Tutor
R6220 - Does NOT support IPv6
Before purchased R6220, I have checked support web site (http://kb.netgear.com/app/answers/detail/a_id/19308/~/ipv6-compatibility-on-netgear-routers) shows that it does support IPv6 on the latest fir...
- Aug 01, 2017
Hi all,
Please update the router to the latest firmware version (1.1.0.50).
Dexter
Community Team
Seta-San
Apr 06, 2016Star
I have scripts and code to test and it I need to verify that it works on a native ipv6 system. Tunneling systems provide some incite but isn't good enough for testing production code.constantly taking the whole network down and plugging straight into the modem isn't an efficient option either. Release the damn firmware update.
DexterJB
Apr 13, 2016NETGEAR Moderator
Hi all,
The update from engineering stated that the official firmware release will be on Q3. However, a beta firmware that supports IPv6 is available. You may send me a message if you are willing to use it.
Dexter
Community Team
