FoxzSnake
Nov 12, 2015Tutor
R6220 - Does NOT support IPv6
Before purchased R6220, I have checked support web site (http://kb.netgear.com/app/answers/detail/a_id/19308/~/ipv6-compatibility-on-netgear-routers) shows that it does support IPv6 on the latest fir...
- Aug 01, 2017
Hi all,
Please update the router to the latest firmware version (1.1.0.50).
Dexter
Community Team
DexterJB
May 29, 2016NETGEAR Moderator
Hi gali61,
As it stands, the beta firmware only specifically adds the IPv6 feature for the R6220 and given it's beta status, it is still under observation. You may manually flash the regular non-beta firmware. There is also no ETA on the release of the current beta firmware as a stable firmware.
Dexter
Community Team
Orosta
May 30, 2016Star
I did notice some slowdowns specificially with web browsing but also intermittent lag while watching streams, speedtests showed I was getting full speed but for some reason it felt like I wasn't receiving high enough bandwidth. Re-flashed 1.1.0.34 and everything is well. I appreciate the trial of the firmware, though. Adding input for further research.
