FoxzSnake
Nov 12, 2015Tutor
R6220 - Does NOT support IPv6
Before purchased R6220, I have checked support web site (http://kb.netgear.com/app/answers/detail/a_id/19308/~/ipv6-compatibility-on-netgear-routers) shows that it does support IPv6 on the latest fir...
- Aug 01, 2017
Hi all,
Please update the router to the latest firmware version (1.1.0.50).
Dexter
Community Team
Prezsley
May 10, 2017Guide
Since Netgear is no longer helpful...here is the firmware
https://www.mediafire.com/download/qf3hvybsj1ufor2
- ElaineMMay 19, 2017NETGEAR Employee Retired
Hi Everyone,
The IPv6 support is now fixed in the latest firmware version 1.1.0.42.
https://kb.netgear.com/000038690/R6220-Firmware-Version-1-1-0-42
- ElaineMJul 20, 2017NETGEAR Employee Retired
Checking on this. We will provide an update soon.
- himemiyaJul 20, 2017Aspirant
Prezsley wrote:Since Netgear is no longer helpful...here is the firmware
Firmware upgrade failed. Please check your file.
- DexterJBJul 20, 2017NETGEAR Moderator
Hi all,
We are looking into this.
Dexter
Community Team
- zooweeJul 22, 2017Aspirant
DexterJB wrote:Hi all,
Dexter
Community Team
Hi DexterJB,
This needs to be escalated. I work in an IT environment and while we do put things like this on the back burner, I have NEVER had it sit there for that long. You're hoping we forget about it. If you guys were actually concerned about this, you would update your product page to not have one of its features be IPv6. People keep buying this router expecting it to support IPv6 and it still doesnt. Ive had this router for almost a year now and one of the main reasons I bought it was its so-called ability to use IPv6. Think of how many other people bought this router and are unaware of this issue. I had faith in you guys when trying to release it by march but that deadline was ignored. While beta versions of a firmware update are nice, it doesn't solve the original issue. There needs to be a full release of a firmware update, not a request to get a beta firmware. It really seems like you guys could care less about this product now because they sold and thats all that matters to you. If this doesn't get solved by the end of august I will not be buying or recommending any of your products anymore.
This is ridiculous.
- DexterJBAug 01, 2017NETGEAR Moderator
Hi all,
Dexter
Community Team
