xplicit
Dec 02, 2015Aspirant
R6220 - Toss or Continue troubleshooting?
Let's cut to the chase, I picked this router up at Costco sometime around April or May as my old ASUS RT-N56U started stumbling my connections consistently despite being 2 years of performing like a ...
- Feb 28, 2017
Hi Existedtoxic,
1. What is the firmware version of the router?
2. Have you tried resetting the router?
3. You can try re-flashing the firmware of the router.
4. Are all devices affected (wired and wireless)?
Dexter
Community Team
DexterJB
Dec 02, 2015NETGEAR Moderator
Hi xplicit,
May I know if you have tried re-flashing the firmware? If not, please try doing so then reset and reconfigure the router. Please keep us posted if there are any changes. You may refer to the links below for the steps.
Dexter
Community Team
- xplicitDec 02, 2015Aspirant
Dexter I have tried multiple different firmwares and anything above the one I have installed always seems to make my Wifi extremely subpar and my Lan connection to constantly DC.
