xplicit
Dec 02, 2015Aspirant
R6220 - Toss or Continue troubleshooting?
Let's cut to the chase, I picked this router up at Costco sometime around April or May as my old ASUS RT-N56U started stumbling my connections consistently despite being 2 years of performing like a ...
- Feb 28, 2017
Hi Existedtoxic,
1. What is the firmware version of the router?
2. Have you tried resetting the router?
3. You can try re-flashing the firmware of the router.
4. Are all devices affected (wired and wireless)?
Dexter
Community Team
Existedtoxic
Feb 26, 2017Aspirant
Is there a solution to this wireless problem? Im having the same problem with my r6220 :(
- DexterJBFeb 28, 2017NETGEAR Moderator
Hi Existedtoxic,
Dexter
Community Team
- DexterJBMar 05, 2017NETGEAR Moderator
Hi Existedtoxic,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
